How to plot a two-dimentional matrix?
ptc-4676289
In Mathcad we can easely plot a two-dimentional function z=Z(x,y)
Is there a way, to plot a two-dimentional matrix z=Mj,j ?
Thank you!
8 REPLIES 8
(To:ptc-4676289)
Sure, if you are happy with the indices i and j to be taken as x and y values you can plot M the same as f via quickplot (= simply put M in the placeholder of the 3D-plot).
If not you would need the vectors of associated x and y values and would have to create a data structure of nested matrices like createmesh() produces.
Thank you very much!
One way to do it: M[i, j -> f(x, y) -> Surface
or Mathcad Prime
and the plot
Thank you very much, Valery!
(To:ptc-4676289)
Find attached some ways to plot data matrices:
1) Quickplot
2) nested data arrays
3) turning the matrix into a function using
a) linear interpolation, or
b) cubic spline interpolation
Hope you find soemthing which fits your needs.
(To:ptc-4676289)
You are welcome.
So you found, what you were searching for?
Yes, it was very informative and helpful!
