How to preserve a constant when doing symbolic solve?
JohnDoe
2-Explorer
Dear friends,
Is there any possibility to tell Mathcad Prime 2.0 to display constants with their symbols (in contrast to evaluating them) when performing a symbolic solve of a function?
P.S. The constants are defined by the user.
tdevaraj
(To:JohnDoe)
Mathcad Prime 2.0, has a clear( ) function to clear variables for re-use further down the sheet.
Also the clear.sym( ) function allows you clear said variables for use in symbolic applications whilst retaining numeric values.
see example below.
tdevaraj
(To:JohnDoe)
see example below.
JohnDoe
2-Explorer
(To:tdevaraj)
Thank you.
Why the formula is becoming grey after using clear()? (see my attached example).
I used clear_sym() also in other projects an most subsequent equations turned grey. Is this normal?
What is the opposite to clear_sym()? (to make evaluating of variable possible again in symbolic solve).
tdevaraj
(To:JohnDoe)
Answer: There is no opposite...see explanation in screen shot
