How to restate the formula again below?
XN_10549151
I have a number of formulas that are the same but the variable value are different. For consistency and if just one region is copied to another sheet I'd like to restate the function again. So that if the region is copied to another sheet then I can just changed = to :=. Is this possible in mathcad?
FYI for anyone interested. What I ended up doing is just disabling the region. It's not exactly what I wanted and I wanted to carry the formula down so I can have the occasional visual check at that point.
To Continue clicking Evaluate until each part of the formula has been evaluated. To see the evaluation again, click Restart. To end the evaluation, click Close. Try this may be this will useful for you.
