How to save a contour plot in separate file other than mathcad?
vvenkatesan
Contour plot can be done using the graph option in mathcad. But, i need that in an image format which can be opened outisde mathcad atmosphere. Is it possible? if it is means, could you explain me?
RichardJ
(To:vvenkatesan)
If you save it in HTML format the graphs are saved as images.
Or Ctrl+A - Point and copy this plot in ClipBord
... or save the data to Excel and use Excel to do a contour plot (replace Excel with whatever other app springs to mind that does contour plots)
Stuart
