How to solve this linear equation
dkothia
How to find the value of a0 and b0 in terms of x. Please reply ASAP.
Guess values must be not yours but a0:=1 b0:=1 for example.
And you must have as an answer not vec, but vec(x)
Send please the sheet!
(To:dkothia)
If you are looking for a symbolic solution in x you will have to use the symbolic "solve" command, not a numeric solve block.
In Mathcad (15 and below) we were able to symbolically evaluate a solve block, but unfortunately in Prime this is not possibly anymore.
You can get numeric values for specific x using the solve block, but not a symbolic solution in terms of x.
Not willing to retype the expressions from your screenshot, so here is a simpler example which shows how a symbolic solution can be derived.
WE
