How to symbolically derive a function with respect to a function
sfan
Please see the attachment.
In Lagrange Equation for Dynamic equation,
there is a term that request the derivative of T(t) with respect to (u(t))',
I don't know how to achieve this.
Looking forward to your help!
Thank you very much!
LucMeekes
(To:sfan)
From what I see you have this (assuming your formulation is correct):
Which means you have a function T(t) which is found from the function u2(t) by first taking the derivative of u2(t) with respect to time: u'(t)=d/dt of u(t). Then square the resulting function squ'(t)=u'(t)*u'(t). Then multiply the result with a constant (assuming that a, b, and the three m's are known). This should be simple, provided that u2(t) is given...
Are you sure you don't need a second derivative of any functions u and v, rather that the first derivative squared...?
LucMeekes
(To:sfan)
sfan
(To:LucMeekes)
Hi, Luc
So by this step,
Is it possible to let Mathcad derive T(t) with respect to du2(t)/dt?
Which will result in:
It is to set du2(t)/dt as the argument and the others (including u2(t), if exists) as constants.
Thank you
Best
Shawn
LucMeekes
(To:sfan)
Hi Shawn,
No, If you feed that first expression AND u2(t) to Mathcad it will take the deriverative of u2(t), then square it and multiply the resulting function with the constant involving a, b and the three m's. The result you mention is NOT obtained.
Observe my question/comment at the end of my first reply:
