I can`t plot of ellipse in Mathcad 15
jjjjvb
I get only half of графика in Cartesian coordinates because of a root, depending on a sign expression. I could not do anything at all polar coordinates.
Fred_Kohlhepp
23-Emerald I
(To:jjjjvb)
You plot it parametrically
5 REPLIES 5
MichaelH
(To:jjjjvb)
Your formula for r(phi) is incorrect and does not produce an ellipse in polar coordinates.
You also reversed r and phi in your polar graph.
You can produce the ellipse by adding -f(x) to your xy graph.
I strongly suggest that you read the Help file on using graphs in general.
jkowalski
(To:jjjjvb)
see example.
Thank you. I`d like to know whether it`s possible to plot continuous graphic for Cartesian coordinates i.e. without adding -f(x) ?
Fred_Kohlhepp
23-Emerald I
(To:jjjjvb)
(To:jjjjvb)
Unfortunately Mathcad is not able to plot implicit functions directly - you have to resort to the workarounds others have shown here.
I remember vaguely a thread in the old collab (which has been moved over and merged into this forum here very, very poorly and faulty by PTC stuff) about automatically transforming implicit functions so they can be plotted by mathcad.
You may search the forum for "plot implicit function". But as far as I remember it was neither easy nor comfortable nor perfect.
Werner
