Identify variable with maximum value
ppal
18-Opal
(To:ppal)
You may also omit the "augment" function in "max" when using Luc's solution.
Depending on which way you need the result, you may turn it into a function.
Unfortunately there is no way we could automatically access the name of a variable.
Prime 10 sheet attached
LucMeekes
(To:ppal)
Use
match( max( augment( A, B, C)), augment( A, B, C))
And inspect the vector of results.
Update:
See attachment
MartinHanak
(To:ppal)
I was curious and tried Luc's solution.
Martin Hanák
(To:ppal)
Hello @ppal
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
