Image processing
JW_9781974
7-Bedrock
Image processing
When I rotate a coloured image using the functions in Mathcad Prime recalling the image turns out to be in gray scale. How to make Mathcad prime call the rotated image in its original form?
LucMeekes
(To:JW_9781974)
You've got the wrong order of colours for assembling the rotated picture. The order should be RGB, you've got RBG.
Your augment should be:
Consider defining, for rotation of colour pictures:
LucMeekes
(To:JW_9781974)
If you attach your Prime worksheet, we can better help you...
It appears that you must rotate the red, green and blue segments individually:
Here's rotation of a 4 x 4 pixel colour image over 23 degrees:
The resulting image is 4 by 6 pixels, but colourful.
Thanks for the information I tried following the procedure but the color is not same
LucMeekes
(To:JW_9781974)
