Hello community, I'm new to Mathcad so I need your help ![]()
I try to calculate indefinite integral but it doesn't work, maybe I'm doing this wrong way?
Sometime Mathcad is a bit touchy and you have to be more precise:
As you can see the results differs in sign depending on which part you'd like to integrate.
And sometime it sufficient to tell Mathcad that a variable is real only:
Hmmm. Mathcad 11 gives this:
and simplification...:
The same.
Further exploration:
Quite a different result between Mupad and Maple!
As far as I know two integrals of the same function can be different only by a constant. So IntF(x) and intF(x) with different shapes, must have different derivatives...
But when differentiating the results:
I come back to the same F(x). Where's the mistake?
Ah, this looks more like it:
I guess Mupad goes wrong for x<0.
Mystery (partly) solved:
That makes the (green) curve for far negative x going to -3 go to 3*pi, while for far positive going to 3 it goes to 0.
The result should have a signum with x in the acos as well:
Still the results of Maple and Mupad differ by more than a constant (because the constant changes sign with x).
better is if the signum is only the below root:
Now we're talking... But I like the Mathcad 11 (Maple) answer better, becaus it's more symmetric, like F(x) is.
Within a certain angle range we have asin(a) = atan(a/sqrt(1-a^2)) which explains the atan expression in the Maple result.
I am surprised that Maple does not simplify the factor
to sign(x), which in fact it is. After all as far as I reacall we don't have to tell Maple the we are dealing with reals - thats (in contrast to MuPad) automatically assumed.
The different domains of atan and asin also explain the vertical difference between the two solutions which, as I guess, is exactly 3*pi/2.
Mupads result seems to be wrong for negative x.
It rather should be
Would you call that a bug?
Yes - guess its a bug.
Mathcad seems to know it:
Some further strange results:
BTW, Wolfram Alpha agrees with Maple:
And I have some bad news for Prime 4 users:
Bad!
But better than a wrong result 😉
EDIT: I should have known it as its the same in Mathcad 15. We need to use "simplify" !
Here some other examples to demonstrate MuPads .... aehh .... capabilities.
Prime 4 didn't change with respect to that:
But I think it is weird, at least, that you would need a 'simplify' to make it remove the integral:
I won't call it weird - maybe just because I am used to it.
But ist quite OK to me that Mathcad does not make a simplification unless explicitly stated. In fact I would like to have much more control as to when an how Mathcads symbolics "simplify" an expression.
Same basic terms are automatically simplified by Mathcad, but just slightly more elaborate expressions need the command "simplify":
Is it different in MC11 with Maple?
It is slightly different in Mathcad 11/Maple:
But I made my remark because I was surprised about the fact that a 'simplify' is required to evaluate an integral.
I would understand that the simplification of
results in:
would result in
simply because the right part looks 'simpler' then the left one.
It makes no sense to me that when
gives
without simplification, it suddenly produces
when simplification is called for.
Anyway, I'm still very happy with Mathcad 11:
which 'simplifies to:'
(The same)
Maple (within Mathcad) does NOT automatically assume variables are real. Otherwise why would we have these symbolic keywords:
and the manual states:
Hmm, "complex" was put at the modifier panel in Mathca 15.
I remember that Mathcad 14/15 often produce undesired results including expressions with the imaginary unit even though the result would simplify to a real if we assume all inputs are real. Whereas MC11 in the same case delivers a beautiful real result
And some expressions won't simplify fully in MC14/15 unless we assume that the inpunt vars are real where MC11 simplifies without having to assume that.
Remember some older threads about those effects.
