Hi, I need an advice with my problem... I make a static design of steel beam..and I want to read parameters(like A,Iy,Iz etc..) of steel cross section like HEA,HEB,IPE and others EN steel profiles from my excel table..I did it with READEXCEL argument but I think it is too complicate for me to make cca 2000 arguments ( *LOOK ATTACHED MATHCAD FILE) , because I have around 2000 steel profiles. I am looking for advice how to do it easier. And It is possible to show parameters for choosed profile in Table not in Matrix? I want to results look like table with 2 columns and x rows... in first column will be name of parameter like A,Iy,Iz, etc. and in second column will be value of those parametes, which will change depend on chosen Steel profile..
My next problem is how to insert jpg. picture like matrix to mathcad??...
Thanks for answers
