Integration between MathCad and Inventor
salchow27
Is there any functions in MathCad or Autodesk Inventor that can integrate them with each other?
I expect that Inventor can automatically generate the drawings with the dimensions relevant to the calculation result in MathCAD.
8 REPLIES 8
mzeftel
(To:salchow27)
Visit this page on the PTC website, http://www.ptc.com/community/free-downloads.htm and scroll down to Mathcad Downloads. You'll see a Mathcad/Autodesk Inventor integration. Our services group developed it.
Mona
I downloaded the file but couldn't install it because the Installing Guide file included is wrong. Pls see the attched error message in Windows
mzeftel
(To:salchow27)
Carla,
Did you read the Word file on how to install it? It only works on an XP computer. Make sure you have the right version of .NET.
I don't have Inventor so can't do a full test.
The free downloads of integrations were developed by our services group, not the development team, so are not fully supported.
Please try the install again following the instructions in the Word file, and if you still have problems, I will report them to the services group.
Mona
Thanks for reply. In the attached 'Inventor � Mathcad User Guide' file, if you look at the 'How to Install' section, 'b'step is blank.
If I followed the installation steps, warning messages mentioned in my previous message pop up... My system is Win Xp 32-bit. Please advise...
mzeftel
(To:salchow27)
Carla,
I just looked at your error message more carefully, which you should do too.
You put a > in front of the directory listing, which the error message is saying is not a command.
The line should say:
C:\windows\microsoft.net\framework\v1.1.4322
as it does in the documentation.
Then type in the command prompt line:
regasm /codebase C:\mystuff\bin\ MathcadInvAddIn.dll
Also the step b. in the Installation Guide is not missing, it's just a typo on a blank line.
Mona
RichardJ
(To:mzeftel)
On 11/19/2009 2:11:05 PM, MonaZ wrote:
>Carla,
>you should do too.
>a command.
I didn't even bother to look at this, but that is not correct. That's just part of the prompt.
>work\v1.1.4322
No. It needs to say
cd \windows\microsoft.net\framework\v1.1.4322
then the regasm command will work.
Richard
I tried again but still couldn't integrate the Mathcad into Inventor.
The software version I used is :
Inventor 2008,
Mathcad 13,
What I did is:
1. save the MathcadInvAddIn.dll file to the following folder - C:\mystuff\bin\ MathcadInvAddIn.dll
2. typed regasm /codebase C:\mystuff\bin\ MathcadInvAddIn.dll
Then the error message is showed, please see the attached 'error'file.Is it because the version of the software? or any requirements for the operation system?
There are another 3 files in the 'bin' folder downloaded from PTC as showed in the attached 'Download files'. What is these files used for? Do I need to use 'regasm' command for them?
Could anyone advise?
Do you try to registre under other net framework version? Last it's 3.5.
Regards. Alvaro.
