Intellisense or input assistance?
rharenberg
I'm just starting to play with Mathcad and I'm curious if there is any built-in intellisense or some type of input assistance that would help the user input previously defined variables.  For example: if I create a variable LtRailHt:=1, later on in the worksheet I would like to just start typing ltr... and see a dynamic assistance list as I type that helps me find those variables (regardless of the upper/lower case) - then TAB to insert it.
Currently, if I don't remember the variable I want to use - exactly as typed - I will have to go back and find it.  On a large worksheet with numerous variables being defined, this is a big drawback (in my opinion).  It seems most other programming interfaces I use nowadays have some sort of assistance while you type.  Hopefully, I just need to enable something in Mathcad to make it show.
Thanks for any help.
(To:rharenberg)
Unfortunately there is no such feature. Neither in Prime, nor in Mathcad.
I agree that this would be a handy feature, but I would not hold my breath for PTC to implement it.
(To:rharenberg)
LucMeekes
(To:rharenberg)
Mathcad is not a programming interface, nor a programming language. No intellisense therefore.
I can see the benefits of the feature, even for an application such as Mathcad. You could make it a feature request for a future release, but with the rate of updates of Prime so far it will be long before we see it being implemented.
As a work-around, you can always test if a variable is defined, by typing its (presumed) name and evaluating it. Mathcad will change the evaluation operator (=) to a definition operator (:=) if the variable is undefined. If it is defined, you might recognise it's the right one by its value shown.
(To:LucMeekes)
The free russion Mathcad clone (?) SMath Studio has a similar feature already for a long time!
Ok. Thanks for the replies.  Just wanted to make sure I'm not missing something.
