Buenas noches comunidad, tengo un problema en una interpolación. lo que estoy bucando es encontrar un Q que sea constante (interpolación). Gracias por la atención. Version de Mathcad Prime 9.00
PDF version and Prime 10 version
Uses solve block to get solution to channel equation.no need to write another iteration method.
Cheers
Terry
Thanks Luc
Hello @DC_11916766,
It looks like you have some responses from our community champions. If it helped you solve your question, please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
