I am doing a hydradynamic calucation in MathCAD, Now i need to get the right coefficient as a output from table of value (row and cloumn). the input for the interpolation is 2 variable each from cloumn 6 row..Please see the attachment for the better understanding
Your image is like empty ? it killed my box 3 times !!!
This kind of project requires a work sheet .
Is it possible to post the worksheet? When viewing your image my computer froze and I have to close my browser.
The image is to small to view also.
Mike
Have a look at the attached worksheet, I think this is what your after.
Where there are blank spaces in your data I have inserted as zero. The image has also been re-attached for clarity.
Mike
Thank yor verymuch... it worked excellent..
You could edit your original post for the purpose of removing the image that did crash at least Mike and myself.
A more complete tool attached Mathcad 11.
jmG
Thank you.. I have updated the attachement....
Thats better .
If the question has been answered you can indicate by selecting "correct answer" on the post which answered the original question - helps other collabs when trawlling through posts.
Mike
