Is This Number A Real Number ?
lvl107
20-Turquoise
Hello, Everyone.
Thanks in advance for your time and help.
Regards.
10 REPLIES 10
I'm going to say yes its a real number, and good luck with that equation.
Which equation?
(To:lvl107)
According to Mathcad its a real number, just use Im(....) - it simplifies to 0.
We have new operators and built-in symbols in Mathcad Prine:
lvl107
20-Turquoise
(To:lvl107)
And a related query : ( and need help with an explanation )
Regards.
(To:lvl107)
1) Mathcad isn't perfect 😉
2) Maybe you should type 1i instead of just i if you want i be the imaginary unit
lvl107
20-Turquoise
(To:Werner_E)
Many, many thanks, Werner.
Regards.
(To:lvl107)
No problem. The simplification should work with any constant in place of i, but Mathcad's symbolics is obviously better in simplifying the difference than doing it with the equation. So the conclusion is: If you want to know if two expressions are the same, its better to simpliffy their difference than to evaluate the appropriate equation.
lvl107
20-Turquoise
(To:Werner_E)
It seems your hint :
always works :
Best Regards.
(To:lvl107)
If you want i to be the imaginary unit you must type 1i, otherwise i is an arbitrary unknown. Thats the reason for the red error which stems from the numeric processor.
But the expressions you sent first are the same, no matter what i is. But Mathcad had difficulties to see that they are equal unless you evaluate the difference of the two. With i as imaginary unit Mathcad did a better job.
