Is it possible to insert the portion of the file name in MathCAD header
ptc-4497948
I am using MathCAD 15, i want to insert the portion of the file name in to MathCAD 15 header as well as worksheet text region.
For example my file name is “Machine design” I want to insert the header or worksheet text region “design” alone.
One first idea.
For folder name...
Would this work in the header?
You could change the margins abc use Valery's method and just manually place the title in the correct place.
Mike
Do you want to insert the whole file name or just a portion of it?
If a portion, how do you know which portion?
Why do not you use "Header and Footer" tool (in main menu go to "View" -> "Header and Footer ..." -> "Tools: Insert File Name")?
