I have a function where in a form of f(x):=1*x+3. I was trying to use clear(..) function to this clear the this function[clear(f(x)] like I do with the rest of the variables. But then MathCAD gave me error red box around the and said "A variable name is required here". What exactly happens here and is there a way to fix it? Thank you!
You just need to give it the function name.
Stuart
Addition to the information provided by @StuartBruff the following article may also help for more clarification.
Vipul
