I'm using Mathcad 15, and when I want to select multiple areas, I only can use "rectangle select" or "shift or ctrl"+left mouse click, that's very troublesome.
Is there any function like other CAD software, that I can group or ungroup many math or text areas? Then I can select and move them together, and I can enable and disable some areas once click.
And Happy New Year Everyone! ![]()
No, you can't group areas. It's a long standing request.
The only thing possible is that you put regions which belong together in an area. If the area is collapsed you can select and copy/move it all at once. But you cannot enable/disable all the regions in an erea with one click, which often would be very convenient.
