Issue with Newton-Method
AdamM
3-Newcomer
Hi everyone,
I programmed a Newton-Method, but when I want to get the vector with results, there ist a failure message saying: "This Value Must be a Matrix of Scalar Elements". I unfortunatelly can´t see the mistake and already run out of ideas, but maybe some of you guys could know the solution.
Thanks!
(To:AdamM)
 but I still ends up with the same error.
Right click on the vertical lines (absolute value) and change from "Square Matrix Determinant" to "Absolute Value".
15 REPLIES 15
vlehner
(To:AdamM)
can you attach the file please?
Volker
Alan is right, your inequality needs reversed.  I also had to cheat the index value:
AlanStevens
(To:AdamM)
I think your "while" condition should have "> eps" rather than "< eps".  However, this might not be the only problem, so upload your file as Volker suggested (you have to zip it first).
Alan
AdamM
3-Newcomer
(To:AlanStevens)
Thank for that fast answers. So this is the original file, the inequality sign was of course wrong.
But unfortunatelly that doesn´t solve the problem.
MJG
18-Opal
18-Opal
(To:AdamM)
Verify that you are properly using literal subscripts (.) and array subscripts ([).
I also agree with Alan & Volker.
vlehner
(To:AdamM)
Maybe this could solve your problem.
I made the program by myself, so you should maybe convert it to your variabe names.
But principal it works.
Have fun...
Volker
AdamM
3-Newcomer
(To:vlehner)
Thanks for typing it.
Your file works on my pc. I changed mine, so that it is more or less identical with yours, but it still ends up with the same error.
vlehner
(To:AdamM)
very curious...
I loaded your file and had the same error.
Then i copied my routine into your sheet, changed xneu to xnew and it works.
Try the attached file please and let me know how does it works.
Volker
(To:AdamM)
vlehner
(To:Werner_E)
Impressive!
I changed it too and it works.
Simple changes with effective consequences.
Volker
See please this method on the Mathcad server
http://twt.mpei.ac.ru/MCS/Worksheets/Math/Newton.xmcd
For two equations
vlehner
(To:ValeryOchkov)
Volker
"Solution without animation is not solution!"
                                                      (Valery Ochkov)
Thanks to all for all the useful answers!
