Lengthy symbolic equations
ptc-3082077
I have to evaluate two fairly messy equations,
in terms of several radii and pressures, which I only know symbolically. I have solved these by hand and, as expected, get my sigmas in terms of the radii and pressures. But the expressions are lengthy and I need to use them in other equations. Is there a way I can write expressions which maintain the symbolic placeholders for my varibles?
6 REPLIES 6
I tried to post the equations in the body of the first post, but here are the expressions I am using.
(To:ptc-3082077)
Why didn't you let Mathcad do the work?
Not sure but I think what you need is to make them functions of all variables. See if the attached would help.
This was extremely helpful, thank you for the thorough response. Now I am wondering how I may be able to assign arbitrary variables into my functions (i.e. ri=R_0, 1.25R_0...)
(To:ptc-3082077)
Not really sure what the problem is.
Just define R_0:=2ohm and use it as parameter when calling sigmar(R_0,...)=
What results are you after?
I am solving this entire problem symbolically. I know my radii only in terms of r_0. I am seeking the pressures P_1 and P_2, which will be in terms of P_0 (which I also only know symbolically).That is why I am wondering if there is a way to go from:
sigma_r(r, r1, r2, p1, p2)
to:
sigma_r(r, 1.25*r_0, 1.5*r_0, p1, p2).
(To:ptc-3082077)
to:
You never posted a sheet showing anything of that.
Im not sure if you need a function or wish to solve equations, though.
The attached will at least do what you stated in the last lines - hope it helps.
