From Val Ochkov:
How to solve the lens problem in Prime?
According to the error message Prime expects initial conditions for alpha and beta, even though there is no ODE for these functions
According the second approach and the m^2.
I am not sure if this is as it should be (a bug?) but we get the correct result if the initial value is just 0 or Zero (capital Z. no lower case).
I tend to call it a bug. As the derivative (D, tan) is dimensionless, the solution must be of the same dimension as x and the same applies to the initial value.
Limiting the vector x to values between 0m and 1m was necessary because its last value was very slightly (about 10^-16) larger than 1m and so the function y would fail.
It is informative to try different numerical integrators.
Of course, one could always roll one's own integrator. Here's one I prepared earlier that runs (ran) under Mathcad Prime Express 7.
(I've got a programmed version somewhere of the Runge-Kutta and Adams-Moulton predictor-corrector families that I wrote for M11, but I can't find it at the moment)
