Line break of an calculatet equation ?
Roschee
How can I make an line break of an calculatet equation, like in my attachment.
The key code "Control" and "Enter" are not working, when the equation is calculated.
Roger
You could post your suggestion in the thread below.
http://communities.ptc.com/message/153532#153532
Mike
RichardJ
(To:Roschee)
There is no way to format the result of a symbolic evaluation so that it is on mulitple lines. The only thing you can do is copy and paste the expression, and then edit it.
It would be nice, if Mathcad will make this function available in an new version.
My suggestion is, that the result of an equation will be "line break" ed on the
with of a page.
How can I give this feedback to Mathcad engnieers ?
Roger
Mike
