Having some challenges with advanced controls in Prime 10. I have attached the worksheet for reference.
Would appreciate any suggestions or work around.
Bit of context.. Recent reluctant mover from Mathcad 15 to Prime 10. We do a lot of team collaboration, so we used to use Mathcad 15 worksheets as templates letting the testers to access only input and output sections of the Mathcad worksheet to test the multiple product models before fine tuning them. so, it's critical to fit as many list boxes and text boxes in input section. We are trying this out in Prime 10 and seeing basic challenges compared to Legacy version.
All I can say is that nothing of what you described has been changed/fixed in the current version 11 of Prime.
Hi Werner,
Really appreciate for taking time to respond.
Yes came across that input + symbol issue as well, I was reserving that complaint for another post. But I guess you already gave that answer as well.
Is there a way that we can elevate these basic issues with PTC that will make Prime more user friendly specifically with advanced controls?
Was hoping to get some encouragement moving to Prime but got a shoulder to cry on.
If you are under active maintenance you may open a support case at official PTC support
https://www.ptc.com/support/case-logger
You will have to answer some questions and jump through some hoops until you finally can submit your request.
You also may consider creating a Mathcad "Idea" here
https://community.ptc.com/t5/Mathcad-Ideas/idb-p/PTCMathcadIdeas
but I am not sure if this really would help the program to get improved. PTC claims that *ideas* with a lot of upvotes will be considered by the development crew...
