Hello everyone,
in the attached file, the program should loop through length of dS and store the values in RA.
could someone explain me, why the loop is not working
attached the Mathcad 10 file.
Is this more like the result you were expecting? A change of the outer loop variable to i, moving the d1 assignment into the loop, and deletion of the i←i+1 statement at the bottom of the loop.
Stuart
I don't know what you were expecting to happen, but structurally your program can be summarized as follows:
d1 takes one value (28 cm) and executes the for-loop just the once. The inner loops also only execute once because nob only gets set to zero, hence lloop becomes 0,2..nob -> 0,2..0 which means the n2 loop executes just once, as 0 is the end condition.
Stuart
@NM_10165576 wrote:
Hello everyone,
please explain why do you think that the loop is not working.
I added single line at the end of the 1st page. Is the result incorrect?
Stuart
yeah this is what i was looking for. Thank you.
