Looping Question
salchow27
Looping Question
The function required is comparing the value of BB with the first column of matrix BBfix, find out the figure1 which is most closest to BB in matrix BBfix, then return the figure2 at the same row as figure1 in the second column of matrix BBfix.
BB is undefined.
BB.fix can be defined with units in one step (see attached)
Return is undefined
StuartBruff
(To:salchow27)
On 10/28/2009 1:13:56 PM, salchow27 wrote:
== The function required is comparing the value of BB with the first column of matrix BBfix, find out the figure1 which is most closest to BB in matrix BBfix, then return the figure2 at the same row as figure1 in the second column of matrix BBfix.
See attached for one way. I've saved in M11 format (I note your's is an M13 xmcd file)
Stuart
Thank you very much!! Could you recommend any ebook for Mathcad programming which is avaible for download?
On 10/28/2009 6:24:44 PM, salchow27 wrote:
>... Could you recommend any e-book for
>avaible for download ?
_____________________________
If the e-book "Programming in Mathcad" (version 8 or earlier ) has not not been revamped, then very limited. Keep reading the collab and learn daily practical applications.
jmG
