Loops to Find Maximum Value
ppal
18-Opal
Find the maximum value from a list of data and  also the value that results in the maximum data.
I have attached a mathcad prime 5 file and pic if you dont have Prime 5
(To:ppal)
So here is one way to get what you are looking for:
File in Format Prime 5 attached.
6 REPLIES 6
(To:ppal)
Its not clear to me what values you look at to find the maximum.
Are you looking for the maximum of the 11 values which are calculated by
25*sin(j) * 15*sin(j) * ... * 20*sin(j)
as you write about the max value of the "product" (which?).
Or are you looking at the max of the 88 different values calculated by
25*sin(j)
15*sin(j)
In both cases it would suffice to look for the max of the eleven sin(j)  values and you get the max always for j=1
You may use jmax:=lookup(max(sin(j)), sin(j), j)[0 to find out that jmax=1.
Hi
I am after the max of 88 values.
The function may not be sine it could just be an list of numbers
(To:ppal)
(To:ppal)
Here is a different approach using a used defined utility function
LucMeekes
(To:ppal)
Here's a compact implementation that also works in Prime Express:
Prime 4 file is attached.
Elegant
