MATHCAD - how do I change a function f(x) to a vector so that I can use it in subsequent evaluations (e.g. interpolate)?
rmartin-2
I have a time domain function (damped sine) in MATHCAD that needs to be fft, then attenuated by a frequency dependent vector. To do that I need to:
- perform fft on function
- interpolate the fft with the attenuation
I have tried VECTORIZED with no success. Can anyone help with creating a vector/matrix from a function?
Could you please post your worksheet so that others can see what you've done?
Stuart
Stuart
Stuart - unfortunately, the attached won't tell you much. As you can imagine, I have been trying lots of things; getting frustrated; deleting my attempts.
The worksheet simply defines a function of (t) to define a damped sine waveform with a fundamental frequency that can be adjusted (currently 10^4).
Is the attached something like what you are after?
Stuart
Stuart - this works well.
As an aside - explanation of cfft is very useful. To date, when calculating FFT, I have been forcing everything to power of 2 in order to make fft work. Thank you. Bob
