MAX from a Matrix in Prime.
ppal
Hi all
How do I get the MAX  or Min Phasor from the above.
is the old mathcad version example - I am having difficulty with Prime though.
The greatest dangers to liberty lurk in insidious encroachment by men of zeal, well meaning but without understanding. - Louis D. Brandeis,
(To:ppal)
Heres a one-line solution:
P.S.: I don't see why the method used in the Mathcad 15 version file frome here Vectors with Complex Numbers in Mathcad - PTC: Mathcad - Eng-Tips you had linked to should not work the very same way. After all its basically the same what Fred had shown above.
EDIT: Lets give it a try:
Bingo! Works the same way 😉
8 REPLIES 8
Fred_Kohlhepp
23-Emerald I
(To:ppal)
This is truly strange:
That is because the max function picks  the max real and max imaginary.
Fred_Kohlhepp
23-Emerald I
(To:ppal)
Seems like a bug to me.  You could build a "work around" by finding the index of the matrix of amplitudes.
Seems like that to me too, but it's documented to work that way in the help. So it's a feature that should be reclassified as a bug, and then removed
ppal
(To:RichardJ)
Thanks. Works as I want now.
VladimirN
(To:ppal)
Can you attach your Mathcad Prime worksheet to the message (by using "Use advanced editor")?Pic_1.png
ppal
(To:VladimirN)
I can attach it but it would be not much different to what FRED has shown above.
(To:ppal)
