MP1.0b: Odd behavior with Ctrl-arrow
Ninetrees
I copied a graphic out of an M14 document and pasted it into an MP document. I then tried to move it to exactly where I wanted it. Could not do so. When I place it, it jumps to a place of its own choosing.
The odd behavior is this: I thought to fine tune the location of the graphic by using Ctrl-arrows (up, down, left, right). With the graphic selected and highlighted, pressing Ctrl-arrow causes a different /math/ region to be activated and the cursor moves within that region. The rules don't seem consistent. Ctrl-left, for example, selected different graphic regions to the left and finally stopped on a math region. Once in the math region, the cursor jumped from point to point within the math region in a reasonable manner, and would not leave the math region.
Rich
http://www.downeastengineering.com/
Rich,
Some of the arrow behavior is still being finalized, so it's only partially implemented in the Beta software. You'll have to send a file with steps about what you were trying to do.
Mona
Will do, Mona. I discarded the work because it was just test stuff, but the steps to recreate it are simple enough.
Rich
Mona
Spirit had this same problem, I reported it during the Alpha. It requires one to be absolutely sure where to paste a figure, and that is really inflexible.
Joe
