Community Tip - You can subscribe to a forum, label or individual post and receive email notifications when someone posts a new topic or reply. Learn more!
X
When I try to select an object, I must put the mouse pointer clearly to the right of the object to be able to select it, not on the "Move" region of the object. This is clearly visible at higher levels of zoom.
Can you explain this in more detail? What do you mean by object? A region? Can you send a screenshot? I wonder if it has to do with the resolution of your screen. That is not something we see here, which is why a screenshot might help.
