MathCAD 15 Evaluate Numerically (=) Becomes Definition (:=)
gyorwarth
SUBJECT: Mathcad version 15.0 (M010 [MC15_M010_20110622])
Dear Community,
I have a problem with the subject version and build of Mathcad.
When pressing the keyboard button that should be the equal sign (=) I get the define variable sign (:=).
Even when using the pop up (Evaluation Toolbar) and selecting the equals button on screen the same define variable symbol appears.
Selecting the define variable icon does not make the equals sign appear.
Any help would be much appreciated.
Very best regards,
Graeme Y
StuartBruff
(To:gyorwarth)
In what context does this occur?
If you type 'x' 'x' '=' and haven't previously defined the variable 'xx' then, you will indeed get the ':=' sign, even from the Evaluation toolbar.
If you don't like this behaviour (although I confess to finding it useful), then you can turn it off by going to Tools/Preferences and deselecting "Context-sensitive equals sign' in the Keyboard Options section of the General tab.
However, if you just type '=' in a blank part of the worksheet or if 'xx' is defined, then you should get the '=' sign. Unless anybody has a better answer, then you may need to re-install.
Stuart
StuartBruff
(To:gyorwarth)
Stuart
(To:gyorwarth)
This happens when you try to evaluate a variable which has not been assigned a value yet. As you canot evaluate it (it has no value) Mathcad automatically assumes that you want assign it avalue.
You can change thsi behaviour when you go to Tools > Preferneces... > General and uncheck "Context-sensitive equal signs".
