MathCAD after being launched shows in the task bar and in task manager, but the window is completely off the screen and cannot be seen.
Is there a command that will bring the window back on to the screen?
I asked Google ... application window is off screen
and get following link https://www.technipages.com/bring-off-screen-window-back-onto-screen .
Maybe it helps you to resolve the problem.
I'd pay particular attention to "FIX 1". I've seen these types of issues when the custom scaling factor is set to anything other than 100%.
