3-Newcomer
MathCad 13 vs MathCad 14 - a problem with a "solve" function
- 9 replies
- 3416 views
- Translate All
Hello everyone
I worked on MathCad 13 for years, but recently switched to MathCad 14.
Generally, both versions are very similar, but it turned out that I have a problem - MathCad 14 is not able to solve some equations using the "solve" function, which version 13 solved. After a few seconds of "struggle", an error message appears, as in the attached graphic.
In turn, in cases where version 14 solves equations created in version 13, it does it very slowly - in version 13 they were solved immediately after opening the file, and in version 14 you have to wait a long time, even about 10 seconds.
What is the problem and how to solve it?
I would like to mention that I cannot return to version 13, which I would like to do.
