We are migrating from an old 32bit to a new 64bit server. I have re-installed FlexLM which I also need for other licenses and I got a new license file for MathCad 14. I then just copied the ptc_d.exe from the old machine to the new machine and hoped everyhing would work fine. Of course I also adjusted the upper two lines in the license file to indicate the host name and the lmgrd path.
For some reason I can't get the license started. All other licenses running in FlexLM (for example Autodesk) work fine using the same method.
Anybody any idea what I did wrong?
Thanks in advance for your reply.
Try to contact with PTC's technical support by creating a new "Case", here: http://www.ptc.com/appserver/cs/case/case_logger.jsp
Also you can use "Mathcad Installation & Licensing Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
