MathCad indexes and scalar product
ptc-4765498
hey guys,
got a little problem on MathCad, this being the fact that I don't know how to make epsilon w j feasible to make make the delta S give a result.
here is the attached file. Hope some one can help me
cheers
Mathcad is complaining that the range 'j' gives multiple results.
One solution is to change the equation to save it into an array defined by j
Andy
Andy
cheers, but then with all my different equations and definied variables and stuff like that, that i have not included in this attached file, it says that epsilon w has the form of time^-1 and should be a fonction ...
cheers
Hi Xavier,
a little strange, the definition in the file attached gives results in Pa as you expected in the delta s equation.
What is causing your full sheet to report that this is now returning anything other than this?
can you supply more detail abut the mathcad sheet?
Andy
Well basically, I m working on pressure in dies and things like that> conditions for sheet metal forming. I can send you my whole document, but it might take you a while to read though ...
if you are interested, I will post it on my wall, you can come and see.
Cheers very much anyway
