MathCad results in Excel
ptc-6639785
Does anybody know if there is is simple way how to assign mathcad result from matrix to excel specified cell. I got formated excel table which I want to fill in certain cells with results. I enclosed the simplified file where is easy to understand which result should go to which cell. Any tip is really appreaciatted. Thanks for help. David
You have to specifiy the input cell. See attached.
7 REPLIES 7
Thanks a lot Mike for answer. Just got back into this task. So you entered starting cell of the excell tabel as first input from mathcad matrix. Am I right? Capture.JPG
Yes. As 'Foundation_Forces_HW_Max_Pull_Load' is a two column four row vector it will pass all those value starting from B4.
Thx a lot for your effort. Best Regards David
No problem at all David. Did you manage to complete your task?
Hello Mike, I did complete it, As well combine several matrixes into one table. It went smooth. Also the result is now converted to kN as original matrix.
Good stuff. Would you mind marking this thread as answered to others know.
