Hi, guys im trying to solve this equation and get the value of coefficients (alpha1,2,3) and it doesn't work. Do you have and suggestions on how to solve this? I would like to use it in the future, so it should be parametric. I attached a screenshot and file. Thanks.
If you want a quantity "f" to be depend on variables "x" and "y" you have to define a function -> f(x,y):=....
If you use symbolic quantities you can't evaluate numerically (the normal "="). You may evaluate symbolically (the right arrow "->" you get by pressing Ctrl .)
I also wonder why you define variables with units just to make all expressions thereafter unitless !?
The attached sheet is not working as you expect, but should give you a starting point.
Oh, I see. Im going to check it out thank you. I want to use units but I was searching for error and I thought that is going to be a problem with units compatibility. Thank you.
