Mathcad 13 2D graph problem
ptc-2826722
I used to be able to put lots of traces on a graph. Now, when I get 4 of them trace 2 starts refusing to make lines or symbols. I select a line type, press apply, and the line type reverts back to blank.
RichardJ
(To:ptc-2826722)
Are you running 13.0 or 13.1? If it's 13.0 then download the service release. If that doesn't fix it, we would need to see the worksheet. This forum has ridiculously low upload limits, so save the file in compressed format. Either that, or post it over on this forum: http://collab.mathsoft.com/~mathcad2000 Which is the main forum anyway (this is a backwater, with relatively little traffic) Richard
Check the other attributes of the trace. The various trace properties are not independent, and some trace types do not allow the specification of a line type.
