Mathcad 14 List Box Output
CarlB
Hello all,
I am relatively new to Mathcad 14. The problem I am having is with List Boxes.
In the attached document, you can see two list boxes. The second reads the output from the first and displays a different result based on what is read in from the first list box. The problem is that the outputs in list box 2 accumulate, as opposed to being replaced. I have tried solving this problem using the ResetContent function, but then I was unable to make the selection (it would not stay highlighted).
I would greatly appreciate any help,
Carl
One method is to add a persistent 'variable' that monitors for a state change as attached
Hope it helps
Hope it helps
That's perfect! That's one way I had tried to solve the problem, but couldn't get it working.
Thanks a lot!
RichardJ
(To:CarlB)
There's a large selection of example scripted components here: Extra Components.mcd
There isn't one that does exactly what you are looking for, but the dynamically filled listboxes use the same technique Andy shows. If you look through these you might find a lot of example code that will help in the future.
