in the attached mathcad15 sheet, there is a region that contains math regions in it. I find it difficult to manipulate or move math regions around. how can i get rid of that large regions and have each region by itself? I am not sure of the point making it like that.
Sam
Hi Sam,
Here is how to do it in many regions that make for much better editing. File enclosed below.
Hi Sam,
You have made it all one text region with embedded math.
It is more usual to use many discrete regions of either text or math
It will take time to cut and paste you worksheet to show you. Post it later
Terry
Hi Sam,
Thank you so much Terry!
Sam
