Mathcad 4.0 Loses Pagination
wlangford
3-Newcomer
G'day,
There seems to be a bug in Mathcad 4.0 where it just loses pagination and things creep above the page break line.
I've spent about an hour trying to fix a many page document only to hit save and they randomly creep up again.
Is there a solution for this?
Wade
LucMeekes
(To:wlangford)
I guess you're the first to notice this.
My advice is to report it to PTC support.
DJF
(To:wlangford)
Only just switched (permanently?) to 4.0.  Haven't seen that yet.  However, the prime GUI in general has many bugs.  I think it gets confused with the various grid spacing options. So you might switch between those.  But when you do it moves everything around.
Raiko
(To:wlangford)
The cynical answer is to use mathCad 15 I'm afraid. MathCad prime not only lacks functionality but also maturity.
Raiko
Please send your issue to PTC's tech support by using "Mathcad Support Center" (you can do it, even if you use Express version of  Mathcad Prime):
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
DJF
(To:VladimirN)
I believe that only Enterprise users can actually report a functionality issue.  Other users seem to be limited to licensing and installation problem reports.
