The only thing that changed is the 1809 Update on my OS so I guess that's the cause but I don't know how to fix it.
Also Mathcad 4 does not work either.
Things I've done to try and fix:
- Delete and restore/ delete Mathcad related stuff in my AppData folder in Local and Roaming and Temp
- Reinstall countless times on different hard drives (both version 5 and 4)
- Turn off UAC/ Antivirus before installation and/or completely
- Checked to see if Mathcad window was just hidden, it wasn't
- Install all the vcredist, msxml and .net framwork stuff
This all applies to Mathcad 4 and 5 which worked flawlessly before the Windows 10 -1809 Update
I have the student version and refreshing license does not work either.
The logo appears, fades away and only the background process is left in task manager.
Considering that you've tried everything that's known to correct such problems (to be sure, check: https://community.ptc.com/t5/PTC-Mathcad/Mathcad-Prime-4-0-doesn-t-start-anymore/m-p/492614#M174617), the only thing left is to contact PTC's customer support.
MathCAD needs MS .Net (maybe 4.6, 4.7 ? I am not sure).
See also https://community.ptc.com/t5/PTC-Mathcad/Mathcad-14-0-M020-does-not-start-on-WIN-7-Professional/m-p/326777 (JerzyCierpicki 2011-09-11 09:24 AM).
according to https://www.ptc.com/en/support/article?n=CS277907 ...
1.]
Problem is caused by Bug with Windows security update KB4055002 for Microsoft.Net Framework 4.7.1
2.]
On specific machines it has been noticed that upgrading to .NET Framework 4.7.2 has resolved the issue.
https://support.microsoft.com/en-us/help/4054530/microsoft-net-framework-4-7-2-offline-installer-for-windows
3.]
Microsoft acknowledged the bug with KB4055002 and has released an update to fix this issue.
Users can download and install the fix from the Microsoft catalog
https://www.catalog.update.microsoft.com/Search.aspx?q=4074906
Thank you for the help but none of these work sadly.
Like I said it was working fine before the big update (1809) on Windows 10.
I feel like the only solution is reinstalling Windows 10 or uninstalling the 1809 update but that is not an option for me right now..
if you pay maintenance fee then I suggest you to report the problem to PTC Support.
"Mathcad Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
Try to run Event Viewer (eventvwr.msc) and check whether there are any error messages that give additional information about the failure. Start with Windows Logs\Application log.
Mathcad Prime 5.0.0.0 works fine on Windows 10 Version 1809. We were not able to reproduce the problem. There must be another or additional circumstance that cause the issue.
Rero2, if you still experience the problem please contract technical support.
Thankyou MSheykman or screening this forum!
It's been a long time since someone from PTC staff turned up here.
Thank you for your help but I was not able to find the cause, sadly.
I had to reinstall Windows completely and it is working fine now.
Just to clarify I did not change anything in my operating system, the only thing that happened was the 1809 and it just stopped working.
