Mathcad Prime 10 - Output Incorrect
CP_9809081
2-Explorer
Hi, all.
I have just started using Mathcad. The problem below is driving me crazy. Any idea why it is giving me the wrong output?
See below. I have also attached the Mathcad file.
Incorrect answer:
Correct output:
CP
No, you haven't!
Try putting the vectorization arrow over the right-hand side of YC1   (It's on the bottom right of the Operators menu).
No, you haven't!
Oophs- attached is the Mathcad file.
Yup!  Vectorization required (note the arrow over the right-hand side):
Thank you, Alan Stevens. The vectorization did the trick, it works now. 🙏
CP
