After/while installing Mathcad Prime 2.0 M010, Malwarebytes Anti-Malware ist reporting
[ProgramDir]\PTC\Mathcad\Mathcad Prime 2.0\Help\jre\win32\jre\javaws\javaws.exe
as infected with
Backdoor.Bot.citdl
Not really building confidence!!!
System ist Windows XP SP3, 32Bit
Uploading the file to virustotal.com resulted in an appeasing 0:40 ratio, meaning that none of 40 used virus scanners found something suspicious.
So I would consider it a false alarm, but a drop of bitterness remains.
Same efffect here and I am a somewhat upset and unsettled by it. Anybody can help and explain what the cause for this false alarm (which it hopefully is) is?
Another, more severe case is the secret installation of that "PTC quality agent" which sends back home to PTC a lot of information. I want to be informed about that and have an option at installation time to be able to avoid the installation of that "goodie".
BTW, I also don't like the software (MCP2 now) to insert an icon in the quickstart without my permission. Generally the installation routine needs some polishing, I think. If You want M010 to be installed in the same directory as the previous F001 (program files\Mathcad\Mathcad Prime 2.0) and not the newly suggested PTC-dir, you have to set the installation directory to "Program files\" only, because the dirs Mathcad\Mathcad Prime 2.0 will be created newly in any case. Thats rather unusual as is the way to change the install dir - I had to look for quite a while to find the way to change the install dir.
Furthermore, apart from not informing the user about that agent program, the default setting is to _enable_ the agent and the default filter is to send roughly abaut any information to PTC thats possible.
You have to find out yourself by chance about that program and that you are able to disable its function in the Mathcad options and filter what kind of informations it sends by calling the agent itself (why not all in one place - oh my god!). Or do it as I did and uninstall the agent complete.
As I found out by searching around is, that useres of the demo-30-days (and possible the express version afterward) are not allowed to disable and filter the agent! Possible edu-licenses too ???
I also found the information, that Creo refuses to work if the agent is not installed - can not confirm that but hope, this will not happen to Mathcad.
After all, in my opinion the introduction of that "quality" agent spyware and especially the way it was done, is a severe abuse of confidence. If PTC really would be interested in improving their software including their costomers it would have been a good starting point to listen to the users in this forum and comply to the users requests and the for long years standing wishes. Don't have the feeling that Prime was a step in the right direction and the secret underhanded introduction of that agent is simply unacceptable and inexcusably.
I agree with this. It is a gross violation of privacy. I am surprised installing this with no explicit notification and no opt-in (not opt-out!) option is even legal.
winfrod rager wrote:
...Backdoor.Bot...
This is called "Quality Agent". You can delete this application after installing service release M010 of Mathcad Prime 2.0. In the attachments you can find a quote from "Data Collection Policy".
...Backdoor.Bot...
No! The file which is Malwarebyte AntiMalware is complaining about does not belong to "Quality Agent".
Nonetheless the latter could be called malware, too. Especially looking at the way in which it is introduced.
I don't want this spyware to be installed automatically on my computer without my approval in the fist place.
Before I uninstalled that thing i realized, that i would not be able to filter any of the data beeiing sent to PTC - all greyed out.
...I don't want this spyware to be installed automatically on my computer without my approval in the fist place...
I agree with this.
Let me address the concerns about the Quality Agent.
Quality Agent is _not_ spyware: Quality agent is installed explicitly and is fully transparent. All information it collects can be reviewed before it is ever sent to PTC.
Opting out for Mathcad users: If you have purchased license, you can disable sending any data via Quality Agent (See Application Menu -> Mathcad Options -> Options).
Opting out for Mathcad Express users: Users of Mathcad Express do not have the option to opt out. Mathcad Express is a free product that you can use perpetually. To help us understand the use of the product, we ask for the infomation to be sent in return.
What is being sent:
* data about the product
* data about usage
* data about the hardware and OS
None of the data is personally identifiable, e.g. we do not collect your username, etc.
To see all the data it sends open Quality Agent application. You can see the complete data that it intends to send on the next data collection -- when you close Mathcad (if you have Creo, the time data is sent may be different).
I do hope you let Quality Agent continue to collect and send data. This data is valuable to us to better understand the usage trends of the application (for example should we continue to support Windows XP, or invest the resources in other areas).
--Jakov
