Breakdown of formula
  • October 12, 2012
  • 2 replies
  • 7456 views
Hello everybody,
could you help me with this problem in MatCad 14: I do not know how is possible to breakdown formula.
For example:
a=5m
b=5m
(mathcad write formula like this ) A=a.b=25m2
I would be want to write formula like this, without manul write formula: A=a.b=5m.5m=25m2
Thank you
Best answer by ViktorKorobov
Use symbolics command explicit:
Viktor
Viktor
jkrulak1-VisitorAuthor
Thank you
Step-by-step:
http://twt.mpei.ac.ru/ochkov/Mathcad_14/Chapter1/1_018_All_Values_Step_by_Step.png
i have next troubles with mathcad if you have time. I have three problems:
The first is: how i can change the unit in formula. It always change on predefined units.
The next problem is: how can i round the number in formula. It give me on 12 decimal point.
And the last is: when i have too long formula it write me to the edge. Is possible to follow fixed edge?
Thank you
Thank you
See http://communities.ptc.com/message/190243#190243
Thank you again
