Hello, everybody.
I have met some problem when i want to install the Flex License Manager. So, here's the detail of the problem.
Status
Flexible License Manager status on Thu 3/31/2016 13:33
[Detecting lmgrd processes...]
License server status: 27012@VirtualServer
License file(s) on VirtualServer: E:\Licensing_tools\MathCad\License_files\License.dat:
VirtualServer: license server UP (MASTER) v10.8
Vendor daemon status (on VirtualServer):
ptc_d: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: VirtualServer
License path: 27012@VirtualServer;
FlexNet Licensing error:-97,121
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
So, would you mind to help to install the license manager?
Thank you for your help.
1. Send your issue to PTC's tech support by using "Mathcad Support Center":
http://www.ptc.com/support/mathcad_supportCenter.htm
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
2. Try to install license server from the latest Mathcad 15 M045 service release package, here: Thank You for Your Interest in PTC Mathcad 15 | PTC
