I'm writing this as I had to work long on a converted legacy Mathcad document to prime.
Since being forced to convert legacy Mathcad documents to Prime I get from colleagues (who're proof reading my calculations) the following questions:
All this proves that Mathcad Prime is far from the "...professionally formatted document..." PTC claims to provide. See results in the screen shot below.
1.
Explicit is a means to show the numeric values of selected values in an expression before showing the (numeric) end result. Some people like this.
It works only in symbolic mode. It exists since Mathcad 14 or so...And Prime also supports it. See e.g. https://support.ptc.com/help/mathcad/r9.0/en/index.html#page/PTC_Mathcad_Help/example_displaying_explicit_values.html#
2.
There is no control (never has been) on the numeric output of symbolic evaluations. (I guess in 'trying to be as exact as possible) If you want short numeric results from symbolic evaluations, make sure that all values you use are exact. That is: use 1/10 instead of 0.1 etc.
3.
Is this about the right page margin?
Dear Luc,
Raiko
ad 1)
I guess PTC is planning in a future version of Prime to add the ability to hide keywords, maybe also to replace the arrow by an equal sign. So about 15 years after hard(?) development work you may get partially what you already had 20 years ago. Great!
ad 2)
I am surprised! To the best of my knowledge the setting for the display of numbers never applied to symbolic results.
Can you provide a simplified sheet which demonstrates this difference from MC15 to Prime?
ad 3)
Fully agreed on. But the non-professional look is just one of a lot of drawbacks of Prime.
Hello Werner,
here is an example of Mathcad15 vs. Mathcad Prime handling of symbolics. I had to let of some steam.
Raiko
Arghhh! Of course! Thanks!
I had forgotten about the "Apply to symbolic results" option in the Result Format menu window.
I often miss in Prime the Exponential threshold setting, too.
