I am pretty new to this segment and it would be much appreciated if someone can share some demo parts in Creo Parametric which can be droved by mathcad prime 8 along withn how to do it.
Hiya.
We just had a webinar, "Mathcad for Mechanical Engineers", that shows you that very thing. We also let you download the Mathcad Prime worksheet + Creo Parametric parts used in the webinar replay.
That said, the Prime worksheet is in Mathcad Prime 9, not 8, so you won't be able to open it unless you upgrade your version, or if a generous person backports the worksheet to the lesser version.
Hiya.
Creo also has an ancient step-by-step tutorial with downloadable files in its Help Centre: https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/#page/tutorials_pma/mathcad_tutorials_overview.html
