Has somebody an idea how to find a viewer for Android?
You will not even find a viewer for Windows, let alone for other operating systems.
Well.....essentially Prime Express is a viewer for any Prime sheet, but certainly not more than that. (You can see any stored results, but you cannot successfully recalculate if 'advanced' features are used on the sheet.)
Can you work on Android with Mathcad-sheets on the Mathcad Server?
no, I can't.
I only want to view Mathcad-Files on my Android Smartphone.
Don't want to calculate something there.
As others have said, that's not possible. You have not said which version of Mathcad you are using, but if it's Mathcad 15 then the results are not stored in the file, and so you can't view them unless the worksheet calculates.
If all you want is a dead view of a worksheet with preset input values, why not just print to a pdf and view that on your phone?
I am using MathCad Prime 3.1
OK. There's still no Android viewer though. What's wrong with printing to a pdf and viewing that?
You can use SMath Studio cloud service (through web browser) on tablet/smartphone with Android: http://smath.info/cloud/
